Author Topic: over heating?  (Read 1852 times)
Offline vwjack
over heating?
« on: 12 August 2008, 02:30 »
i have read most of the topics on this but none really pin point any thing thats happening to me!
this is what happens, start her up move 2 miles then the temp gauge is 3/4 and higher. no working rad fan, no lose of coolent and no steam.
i normally just turned the heater fans on full and on top heat to get it down and that worked but now it wont send hot air in at all.
some times the fan comes on randomly when over 3/4 on the gauge mostly when turned off.
i have changed the thermostat which has done nothing. unsure please help.
thanks
jack
Offline Mr Blue
Re: over heating?
« Reply #1 on: 12 August 2008, 06:33 »
That sounds like air in the the cooling system.
Search how to bleed the system. Think RJ has a guide :smiley:
Re: over heating?
« Reply #2 on: 12 August 2008, 11:09 »
if it doing it within 2 mile I'd suspect the temp sensor or wiring is at fault, if no other symptoms of overheating present themselves. do you have an MFA, and if so whats the oil temp?
Offline vwjack
Re: over heating?
« Reply #3 on: 12 August 2008, 17:22 »
its hot its self, after a drive theres a lot of heat coming from my engine and a nice smell. i dont have mfa.
my ideas was to replace the rad because it might be blocked or some thing. but i know nothing?
thanks guys! :smiley:
Re: over heating?
« Reply #4 on: 12 August 2008, 17:24 »
have a read thru my coolant faq, its either under mk2 maintenance or the garage section, covers how to bleed, check the waterpump etc etc.
Offline vwjack
Re: over heating?
« Reply #5 on: 12 August 2008, 17:34 »
is there a way to check the water pump for correct operation.
Re: over heating?
« Reply #6 on: 12 August 2008, 17:35 »
yes, see my faq  :laugh:
Offline vwjack
Re: over heating?
« Reply #7 on: 12 August 2008, 18:31 »
did your coolant system operation. found out my rad has a small leak. i have lost coolant hopefully the rad leak. fan works, prob with the thermostat it didnt opens untill i turned off the engine at about 3/4 on the temp gauge is that ok? i dont think so.
and you rock rj your like an internet mechanic.
Re: over heating?
« Reply #8 on: 12 August 2008, 18:33 »
aha, stuck thermostat, bad!  do you have pas? if not its easy, if not its not so easy :grin:
follow the rad hose to where it connects to the front of the engine, this plastic flange is where the stat is located :)
edit: did you check you get a nice spray o coolant to the top o the header tank when the engine is revved?
Offline vwjack
Re: over heating?
« Reply #9 on: 12 August 2008, 18:37 »
ohh really are europarts- parts that bad, because i changed it like a week ago. i dont have pas.
