Author Topic: Flange Anyone?!  (Read 1869 times)
Offline ToddyGTi
  • I Love GTi's
Flange Anyone?!
« on: 03 May 2004, 14:22 »
The seal between the head and the Water outlet, is it an O ring or a gasket.....and is it known as a Head front water Flange? I have Mrk2 8V Gti and have slight water leak but not from head or rocker...coming from outlet thing.... also my engine revs drop and rise when I dip the clutch before levelling off....any ideas?
Toddy
Part of the Booty Club
Blue MK2
Re:Flange Anyone?!
« Reply #1 on: 03 May 2004, 14:29 »
sometimes the flange thing cracks and needs replacing. about ?5 from VW with the 'O' ring mate
Offline mk1
Re:Flange Anyone?!
« Reply #2 on: 03 May 2004, 14:30 »
Hi Toddy.
Check the plastic flange carefully as these are prone to cracking.
Steve.
Offline ToddyGTi
  • I Love GTi's
Re:Flange Anyone?!
« Reply #3 on: 03 May 2004, 14:38 »
thanks guys.
also it feels like my gearbox mounts are loose as i think it rocks a bit when i gear change, does this happen. This is my first VW. the first of many I hope.
Toddy ;D
Blue MK2
Re:Flange Anyone?!
« Reply #4 on: 03 May 2004, 14:44 »
as for the rev problem, you've probably got air leaks.
Have a look at the rubber seal ontop of the rocker cover. it sits between the air breather and the rocker cover. they split and break.
