Golf mk3
hardmonkeys
Restrictor in air box
Topic: Restrictor in air box (Read 2580 times)
dragongreen16v
03 May 2004, 11:00 »
On my 16v, if you open the air box you'll see a long conical shaped thing on the intake. It can easilly un-clip....so I did. I took it for a test drive and didn't know how it would affect it, I noticed more torque from 80-110! Why is it there? It just seems to restrict air if anything.
Overseer
Re:Restrictor in air box
03 May 2004, 11:05 »
restrictor, or filter?
Veedubgt18v
Guest
03 May 2004, 11:22 »
its a restrictor you can flow more air without it
Veedubgt18v
Guest
03 May 2004, 11:23 »
that was my 1000th post!
dragongreen16v
03 May 2004, 11:44 »
Congratulations!!
Did a bit of research on the net, and it's one of the only free mods that will give you 5 more horses. Apparently, it acts as a silencer. Sound OK without.
Veedubgt18v
Guest
03 May 2004, 12:42 »
now drill the box and get a k+n panel filter!
dragongreen16v
Reply #6 on:
03 May 2004, 12:44 »
If you drill the box, isn't that defeating the objective of having a filter? Where would I drill it and what size hole?
Veedubgt18v
Guest
Reply #7 on:
03 May 2004, 12:49 »
drill the box on the front and wing side, not the engine side! you drill below the level of the filter, in the bit that had the resonator tube, that way more air can get to the filter. i drilled holes 1 inch across
old_boy
Guest
Reply #8 on:
12 May 2004, 14:23 »
Thanks for the tip!
Golf mk3
hardmonkeys
