Author Topic: fuel pump pressures  (Read 866 times)
Offline dubslug
fuel pump pressures
« on: 10 August 2008, 16:48 »
are there any differences between 8 and 16 v fuel pumps...
was told that 16v have almost twice the pressure??
cheers
rik
1992 pearl grey 8v
Offline Jay
  • balding fat cvnt
Re: fuel pump pressures
« Reply #1 on: 10 August 2008, 17:04 »
I think the 16v is a big higher but not twice, after all it's only double the valves not bore size  :wink:
Offline dubslug
« Reply #2 on: 10 August 2008, 17:17 »
understand what ur saying, ive been told its something like 2.5 bar higher or something...
i need more fuel at higher revs and i have a digi 8v and was told to replace fuel pump to 16v one and get a rallye pressure reg...
think the pumps abt 6bar pressure
and pressure regs abt 3???
does this sound right??
also what pressures are standard 1.8 v pressures??
1992 pearl grey 8v
« Reply #3 on: 11 August 2008, 08:51 »
no need to change the pump, the digi one will supply more than enough.  just the FPR on its own will work, either that or just fit bigger injectors.
if you wanted a k-jet pump, you'll also have to swap the under car fuel lines and find some k-jet engine metering head fuel lines to cut the threaded fittings out of.
