Author Topic: where can i buy  (Read 1099 times)
Offline rat-look
where can i buy
« on: 10 August 2008, 11:52 »
the blue sender plug for the ecu and the black temp one? and an idle speed control valve? for a 90 digifant
Offline dubslug
Re: where can i buy
« Reply #1 on: 10 August 2008, 11:54 »
sensors id go to vw themselves, specially for blue one
1992 pearl grey 8v
Offline Jay
  • balding fat cvnt
Re: where can i buy
« Reply #2 on: 10 August 2008, 15:43 »
You can get them from the likes of GSF, but I think most people complain about the GSF ones and end up buying the VW ones.
Offline cняis
Re: where can i buy
« Reply #3 on: 10 August 2008, 17:17 »
vw blue temp sensor is about £15, not sure on the black sensor (water temp sensor for the dash gauge)
idle valves (ISV) will be expensive iirc, better to grab a couple from down the scrappy.
Offline rat-look
Re: where can i buy
« Reply #4 on: 10 August 2008, 21:42 »
cheers will try vw for the sensors do they usually stock them?
Offline Diamond Hell
  • Opinions я Us
Re: where can i buy
« Reply #5 on: 10 August 2008, 21:45 »
Unlikely - they'll order them normally for next day delivery.
Re: where can i buy
« Reply #6 on: 11 August 2008, 08:55 »
the blue one get from vw, the black one is very expensive though, id get it from a breaker.  the actual plugs you should be able to get from vw too, they'll supply with a length of wire to splice in.
