Author Topic: 16/20v head on my 2.0 8v  (Read 5214 times)
Offline dai-cymru
  • 1989 MK2 16V
Re: 16/20v head on my 2.0 8v
« Reply #20 on: 10 August 2008, 13:27 »
when she sees u under the bonnet just say your changing the battery!!!!! :grin: :grin:
unfortunatley as i do a lot of work on cars outside the house she wouldnt fall for it, plus she would start thinking i'm a useles mechanic if it took me a day to change a battery  :smiley:
Offline T_J_G
« Reply #21 on: 11 August 2008, 11:36 »
not really throwing money at it, i would just have to buy a head and gasket and belt set and fit it myself.
what about the ECU and all the wiring. there is probably is a reason why it's not really caught on.
Offline dai-cymru
  • 1989 MK2 16V
« Reply #22 on: 11 August 2008, 16:08 »
wouldnt have thought i needed it as it's only a camshaft sensor on the wiring front that may be different
Offline T_J_G
« Reply #23 on: 11 August 2008, 16:47 »
whatr about the information being sent through the loom?
a 2.0l 8v ECU surly can't be much cop on a 16v head...
Offline dai-cymru
  • 1989 MK2 16V
« Reply #24 on: 11 August 2008, 17:02 »
thats what i mean it's only the cam sensor and with a DOHC cam sensor pick up on one cam so all it will do the same the ecu ony acts on info received so in theory it will react to whatever info the sensors are relaying to it, although may cause problem if it's outside expected parameters, im looking into it at the moment to see if it's viable, you could be right as not many people have carried it out but in essence more power and efficiancy can be had by adding more valves per cylinder
Offline monzablue16v
« Reply #25 on: 11 August 2008, 18:07 »
Bike Carbs.
Offline dai-cymru
  • 1989 MK2 16V
« Reply #26 on: 11 August 2008, 18:17 »
Bike Carbs.
oh yes that would be awesome but serious work me thinks
« Reply #27 on: 11 August 2008, 22:07 »
Bike Carbs.
Oh yes that would be awesome but serious work me thinks
www.boggbross.co.uk ;) :laugh:
Link edited, too many ss's
« Last Edit: 11 August 2008, 23:17 by monzablue16v »
Offline dai-cymru
  • 1989 MK2 16V
« Reply #28 on: 11 August 2008, 23:15 »
links not working for me
« Reply #29 on: 11 August 2008, 23:17 »
Edited :)
