Author Topic: WD40 on Oil  (Read 1994 times)
Offline Jay
  • balding fat cvnt
WD40 on Oil
« on: 09 August 2008, 19:53 »
My brother in law and I just serviced my car in the rain  :laugh: and the numpty when he undone the sump plug didn't have the oil pan in the right place so ofc oil all over the drive... now I sprayed some WD40 over a bit of the oil while cleaning the sump plug and the oil rainbow that was on the floor disappeared when the WD40 touched it, so I tried on another oil rainbow and again it disappeared.
So does WD40 get rid of oil or just mask it?  :huh:
Offline Mr Blue
Re: WD40 on Oil
« Reply #1 on: 09 August 2008, 20:08 »
kind of dilutes it. I use it to clean off the sump plug when going an oil change.
pressure washer should shift the oil on your drive but then you end up with lighter patches and then need to do the whole lot. long :laugh:
Offline bazzza
Re: WD40 on Oil
« Reply #2 on: 09 August 2008, 20:15 »
washin powder will soke some of it up??????????
Offline Jay
  • balding fat cvnt
Re: WD40 on Oil
« Reply #3 on: 09 August 2008, 20:19 »
Well it's on a slope and I just went out to park the car up properly and it's started running downwards into my neighbours fence  :grin: I still put some wet sand over it and sprayed some more WD40, hopefully it will dissipate and run into his yard  :laugh:
Is there anything else that help get rid of oil easier? I don't have a pressure washer unfortunately  :sad: I'll see if my hose can reach that far tomorrow and try blast it off with that.
We only use the liquid stuff that goes in a ball inside the washing machine  :sad: But I'll make sure I get some for next time  :grin:
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Re: WD40 on Oil
« Reply #4 on: 09 August 2008, 20:35 »
gunk is apparently quite good you can buy it especially for drives. also cat litter will help soak it up if theres allot of it.  :smiley:
Offline Jay
  • balding fat cvnt
Re: WD40 on Oil
« Reply #5 on: 09 August 2008, 20:55 »
I've got cat litter but it's the Catsan stuff and it's not fine enough, it's more like little stones than sand  :sad:
Offline DarnPB
  • Formerly Darnpistonbroke
Re: WD40 on Oil
« Reply #6 on: 10 August 2008, 11:25 »
Washing up liquid will remove alot of it. But you need to scrub it in with a stiff brush.
Offline wil0
Re: WD40 on Oil
« Reply #7 on: 10 August 2008, 20:25 »
yeah, washing up liquid, its great at dissolving and removing oil. if it runs off onto the grass, all the worms will come up and you will kill them with the soapy residue. think of the worms! :wink:
pour some petrol on it, and set it on fire, that would work also. :D
3Door Oak Green 91 MK2 16v GTi
Offline JC
  • Back in the North.
Re: WD40 on Oil
« Reply #8 on: 10 August 2008, 20:31 »
front tyre positioined on oil
handbrake on
Build up the revs
and Smoke it off the concrete  :laugh: :laugh: :laugh: :laugh: :laugh: :laugh:
Offline dan7
  • 85 T25 camper, 90 Mk2 16v, 90 Caddy
Re: WD40 on Oil
« Reply #9 on: 10 August 2008, 21:32 »
I usually use sawdust.  :wink:
