Author Topic: sideskirt glue  (Read 2761 times)
Offline Kiddfrost
Re: sideskirt glue
« Reply #10 on: 09 August 2008, 19:04 »
Fin, are your skirts brand new? do they not have the double sided tape on them?
Offline finlayjacobin
  • JUST TOOK AN IQ TEST, THE RESULTS WERE NEGATIVE!
Re: sideskirt glue
« Reply #11 on: 09 August 2008, 19:19 »
Hey Kidfrost, no they are not new ebay specials! new R£" skirts cost a fortune!
Yeah I know they have padded double sidded from new I sat there and screpped it all off before they were painted so I would not scratch them once they were all red!
Fin
56 MK5 GTI TORNADO RED, LEATHER, XENONS, 18 MONZAS, 6 CD ARMREST, EDITION 30 REAR LIGHTS, PAINTED LOWER FRONT AND REAR VALENCE AND R32 SIDE SKIRTS, AUTHENTIC PRESSED GERMAN PLATES, WOLFSBURG PLATE SURROUNDS, INPRO SMOKED MIRROR INDICATORS, CRUISE CONTROL THANKS TO VRSTU
Offline Teutonic_Tamer
Re: sideskirt glue
« Reply #12 on: 09 August 2008, 19:27 »
Try this very handy post of mine - http://www.golfgtiforum.co.uk/index.php?topic=54324.0
Second from the bottom of the BODY section (66-04)
HTH
I feel like a homo
Offline Kiddfrost
Re: sideskirt glue
« Reply #13 on: 09 August 2008, 22:50 »
I fitted new R32 skirts to mine but when I got them back from the bodyshop one of the foam tape backing strips had been peeled off and the tape had lost its stickiness  :angry: After peeling the foam tape off I too thought about silicone but didn’t think it would last. Didn’t want to use a glue as I intend to put the standard ones back on at some point. In the end I used double sided foam tape as this is what they use anyway. I didn’t use the normal white foam tape as I thought this wouldn’t last long once it got wet. I used some dark grey/black tape similar to what was already on there and cut it to size. This was about 9 months ago and no problems so far.
If you do this you must leave the tape backing on. Position the skirt and peel it off while the skirt is pressed in position. Make sure you've got it in the correct position cos you only get one chance..
Re: sideskirt glue
« Reply #14 on: 10 August 2008, 09:48 »
Thanks for the info kidfrost, very similar situation then!
Problem is there are many different foam double sidded tapes for many different aplications, but yes it needs to be waterproof, I have got some trough my work which is designed to fit mirrors with but do not think it will be waterproof.
Fin
Offline RedRobin
Re: sideskirt glue
« Reply #15 on: 10 August 2008, 12:44 »
....I'll be very interested to read what TTshop tell you next week, Fin :cool:
