Author Topic: casper needs help-  (Read 5290 times)
Offline casper
casper needs help-
« on: 09 August 2008, 11:04 »
anyone out there help please,1.9 tdi, 3 door,water ingress problem passenger side soggy carpets any ideas where leaks,read could be pollen filter,any info on overflow pipe beside door hinges also any infi on how to adjust doors sagging slightly cheers.
Offline T_J_G
Re: casper needs help-
« Reply #1 on: 09 August 2008, 17:51 »
read my thread called 'the rained killed my GTi'
http://www.golfgtiforum.co.uk/index.php?topic=88116.0
Open bonnet, look under windscreen and remove the tray with the 4 screws holding it?
It's probably broke. Replace with new and job done That cover is £5 from Vw and pollen filter is £15which i replaced. takes 10 minutes aswell!
DO IT ASAP BEFORE IT BUGGERS UP YOUR ELECTRICS!
Let us know how you get on!
Offline T_J_G
« Reply #2 on: 09 August 2008, 18:02 »
and and if its the pollen filter it will come in to the driver side of the passenger footwell from behind the dash.
Offline casper
« Reply #3 on: 09 August 2008, 19:04 »
Got,the panel off (without breaking it) took pollen filter out which was soaken,will replace tomorrow and let you know how i got on,thanks for prompt reply.
Offline T_J_G
« Reply #4 on: 09 August 2008, 20:10 »
No problem. It buggered up my electrics for a day when it happened to me.
Let the car run after fixing with heaters on and doors closed to dry it out.
So was the panel broken?
Offline casper
« Reply #5 on: 11 August 2008, 09:35 »
No,screws a bit rusty but panel was OK,took the opportunity to get into the wiper mecanism to lubricate and clean out any debris,had a dehumidifier running all night in car to dry out carpets worked good,only problem now,after replacing passenger seat,remembering all plugs etc,AIRBAG warning light stays on does this need reset by VW garage,thanks for the help...
Offline Rhyso
« Reply #6 on: 11 August 2008, 10:04 »
try disconnecting the battery for 30 minutes, if not you need someone with VAG COM to clear the code
Offline Ben_1uk
« Reply #7 on: 11 August 2008, 11:04 »
I've noticed that after it rains, my car steams up quite a lot inside... :huh:
Is this normal?
Powered by the fuel of satan!
Offline Rhyso
« Reply #8 on: 11 August 2008, 11:20 »
Is this normal?
sounds like your pollen filter is getting wet - and unfortunately it is a common problem.
don't think the cover is too expensive - PM Tim aka T_J_G as he just bought a new one
Offline T_J_G
« Reply #9 on: 11 August 2008, 11:37 »
Is this normal?
£15 for the pollen filter from VW and the cover is £5. Got part numbers at home, but i'm not at home  :tongue:
