Author Topic: piece of sh*t gettin worse  (Read 1283 times)
Offline bazzza
« on: 08 August 2008, 17:38 »
hi i had a brain wave  i thought i would rebuild my engine on my 1.8 8v,  new pisten rings,  stem seals big ends an main i have been on b4 about this smokin, i have done about 750 miles since my rebuild when i give it some its smokes a bit then clears but when i am sat still (say mc;s drive thru ) when i set of it smokes would u say stem seals?  i am p*ss off with it now dont know what to do helppppp please :angry:
Offline Dolly
Re: piece of sh*t gettin worse
« Reply #1 on: 08 August 2008, 19:10 »
were the valves and head in good condition, and did you Lap the valves in so they seal nice and tight? and i assume the bores were checked for wear?
what kind of mileage is on the engine?
Offline bazzza
« Reply #2 on: 08 August 2008, 19:24 »
i rebored the bores be for i put the piston s in an i sent the head off to get my stem seals in the engine has done about 130000 but i have put new clocks in last year so cant remember.. dont know what to do?
Offline Jay
  • balding fat cvnt
« Reply #3 on: 08 August 2008, 19:40 »
Someone said they got a 20V NA engine for just over £100, think it might have been danny_p search his threads and see if they make sense to you and if you could do similar.
Offline bazzza
« Reply #4 on: 09 August 2008, 19:23 »
cant find it mate.... it runs alright it just smokes that why i rebuilt it .. it to good to scrap its on a d reg i got it painted two years ago dont wont to  sell it but its p*ss me off an it  went thru it mot three weeks ago i dont work in a garage any more so i ant any tools now what
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #5 on: 10 August 2008, 11:23 »
When you say you rebored the bores, what exactly did you do? Did you just take the glaze of the walls or did you actually remove material? Did you gap the rings properly? What did you do with the valve guide seals? Are your valve guides in good condition? All of these are a factor as to what causes smoking.
If you took out too much material when you 'rebored', the pistons will be a slack fit, you would loose compression, loose power, and, yup, she would smoke, but all the time, not just after she has stood still. You would also get crankcase compression which would force oil vapours into the breathing system which will cause smoking, but again all the time.
Your syptoms indicate valve guides or seals or both.
Or you could be over fuelling. That would cause similar symptoms, but you will also get a strong exhaust fume smell. And the smoke will be black.
