Author Topic: Quick Questions!!!  (Read 1418 times)
Offline Wolfie
Quick Questions!!!
« on: 08 August 2008, 11:53 »
Hi  - can you help or is this a dealer visit?
I have recently had my MFD2 sat nav changed by the dealer under warranty, as a result of changing this they managed to scratch  the fascia around my climate controls - after complaining they put in a brand new unit and surrounding plastics  - result.
The problems I now have is that the Sat Nav states all the distances in Kilometres and I prefer good old fashioned miles - how do I get the unit to convert from km to miles?
and the  other being that when I sychronize the driver and passenger climate control settings with the 3 second hold of the auto button - the two temps converts to 22c instead of what I had mine set to  - for example if i set mine to Lo and then hit the Auto button to synch the passengers side to this  - it doesnt - but sets them both to 22c!?!?    it worked before !!
Thanks in advance  :smiley:
Candy White GTI, 3 Door Manual, Nav, Armrest, 18's, No Mods yet.
Offline AlanD
  • MK5 2.0T 16v
Re: Quick Questions!!!
« Reply #1 on: 08 August 2008, 12:02 »
Does the MFD2 come with an instruction manual? I would have tought its a simple settings button that you need to push to get it back to miles rather than kilometers. I know its the boring option but a good read of the manual will tell you how to put it back.
As for the A/C no idea, sorry.
Offline Teutonic_Tamer
« Reply #2 on: 08 August 2008, 14:42 »
As AlanD said - RTFM  :wink:
Re the air-con, the press and hold method you describe is designed to do that - somthing about optimum factory settings being 22 deg C.  If you want to synchronise the passenger temp to the same as the drivers, just briefly press the "dual" button.
I feel like a homo
Offline Wolfie
« Reply #3 on: 08 August 2008, 15:07 »
Ive looked through the manual and zip! But after playing with the menus etc I eventually solved the problem - you have to go the language setting - there are two settings for english - metric and imperial - just toggle between them for your desired setting - km or miles.
OK TT  - will try the dual button way of synchronising - I think the problem is that when VW changed the climate controls they gave me the updated ones as I dont think I had the dual button previously!
Will make sure I read the manual thoroughly cover to cover next time before I post and stop being a lazy git!  :wink:
Thanks again guys.
