Author Topic: air bag fault  (Read 4708 times)
Offline vwkevgti
air bag fault
« on: 07 August 2008, 00:17 »
ive had the air bag light on in my golf since ive had the car lol 1 year yesterday and scanned it for fault codes all was clear apart from the air bag one 00588 ive tried to delete this before and it just came straight back on. but it went off and stayed off this time should i be worried     :sad:
kev
Offline Ridg
  • TDI - Soot Happens!
Re: air bag fault
« Reply #1 on: 07 August 2008, 08:43 »
if the fault kept coming back then it could be a dodgy connection thats sorted itself out.
does it say which air bag is faulty?
Offline Rhyso
Re: air bag fault
« Reply #2 on: 07 August 2008, 09:51 »
another way is disconnect the battery for an hour and re-connect - that sometimes clears the fault
Offline AlanD
  • MK5 2.0T 16v
Re: air bag fault
« Reply #3 on: 07 August 2008, 10:01 »
Ahhh the good old turn it off and then back on trick, works everytime :D
Offline vwkevgti
Re: air bag fault
« Reply #4 on: 07 August 2008, 10:07 »
it says Air-bag Ignition Circuit - Driver Side -N95
or  Airbag Igniter: Driver Side (N95 in the dtc library
thnks kev
Offline Rhyso
Re: air bag fault
« Reply #5 on: 07 August 2008, 14:30 »
thnks kev
check the connection under your drivers seat - may have come loose  :undecided:
Offline AlanD
  • MK5 2.0T 16v
Re: air bag fault
« Reply #6 on: 07 August 2008, 15:01 »
I generated an airbag fault ,which Ridg very kindly cleared for me last night, when I put in my new HU because I had to disconect it. Even putting it back in didnt clear it and had to be cleared via VAGCOM, it may have come loose or have a dogy connectiong which is causing it to going in and out of fault.
Offline troublestarter
Re: air bag fault
« Reply #7 on: 07 August 2008, 20:36 »
i have had the same fault come up on the clocks today after fitting a phone kit for a customer on their mk 5 bluemotion getting it reset tomorrow (hopefully)
its crazy how just unplugging a h/u can cause such a stupid problem
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline Rhyso
Re: air bag fault
« Reply #8 on: 07 August 2008, 20:38 »
bit daft bu then thats what happens when you buy a MKV  :laugh:
Offline AlanD
  • MK5 2.0T 16v
Re: air bag fault
« Reply #9 on: 07 August 2008, 21:38 »
I have had the same fault come up on the clocks today after fitting a phone kit for a customer on their mk 5 bluemotion getting it reset tomorrow (hopefully)
Its not unplugging the HU that does it, you have to disconnect the air bag to remove the front dash to remove the HU. It's disconnecting this that causes it to go into fault, simply plugging it back in does not clear it (which is stupid imo, probably so you have to go to VW to get them to spend 30 seconds clearing it and charge you £70).
Rhyso, you so wish you had MKV !
