Author Topic: Ap Brake Upgrade on 17's - did redrobin have these fitted ?  (Read 13617 times)
NewGolf
Re: Ap Brake Upgrade on 17's - did redrobin have these fitted ?
« Reply #30 on: 10 August 2008, 15:40 »
have you tried the Haynes manuals for the Golf/GTI? Reasonably priced as well.
It's shyte - typical Haynes crap, often omitting some important points, and blatantly instructing to use petroleum based copper grease on rubber brake components.  :angry:
Try this linky for official factory manuals - http://www.golfgtiforum.co.uk/index.php?topic=54324
TT thanks for the link, and pardon my ignorance, but how do you download these, its all in a foreign language to me and I cant find where to download the manuals on brakes?
Tried to remove the rear disks yesterday, no luck and gave up and painted them in place. Looks better than it did when it was rusty. Going to try take off the fronts if I can find a guide.
Offline SteveP
« Reply #31 on: 10 August 2008, 19:04 »
To download the docs you need to right click on the link and select save as (also must use Internet Explorer not Firefox)
Also this looks like a useful thread from the golfmk5.com - http://www.golfmkv.com/forums/showthread.php?t=40013&highlight=rear+brake+pad
NewGolf
« Reply #32 on: 10 August 2008, 19:31 »
Thanks SteveP.
I undid the disk/rotor screw, but couldn't get the disk/rotor off, do you have to give it a slap with a mallet or something? Mine didnt come off on either back wheel.
Offline SteveP
« Reply #33 on: 10 August 2008, 19:36 »
Thanks SteveP.
Not tried it myself yet on the Golf but would expect it needs a bit of force to detach it from the hub after being on there for a while with the constant temp changes and pressure from the wheel.
Do you have any pics and what paint did you use?
Offline Teutonic_Tamer
« Reply #34 on: 11 August 2008, 11:00 »
I might check it out when I've caught up with all my forum posts :tongue:. That'll be sometime tomorrow then.
LOL, if you are like me, trying to catch up with all the posts is like trying to paint the Forth Bridge!  :sad:
I feel like a homo
« Reply #35 on: 11 August 2008, 11:09 »
Yup, as SteveP states, right click > save target as.  Save it to a convenient folder on your hard disk, then once youv'e downloaded them, they are there to stay, even if the host site goes down - and we all know that can happen, don't we <cough> jv <cough>  :grin:
As well as removing the sliding part of the caliper (which contains the piston), you also need to remove the caliper carrier from the hub carrier, before removing the disc.  This is standard practice for virtually all disc brakes with sliding calipers.  When you do remove the carrier, it is very important to clean up the bolt threads with a wire brush, AND use a thread locking compound, such as PermaBond A130 or Loctite 2701.  A wee dab on the sliding pin bolts is also good practice.
http://www.golfgtiforum.co.uk/index.php?topic=54324 - first one in the BRAKES section.
I feel like a homo
Offline dani_and
« Reply #36 on: 21 March 2011, 11:09 »
Hi
Someone can tell me who has the best price for this brake kit?
Thanks!
