Author Topic: clutch!!!!!  (Read 5417 times)
Offline stealth_gti
clutch!!!!!
« on: 02 August 2008, 16:11 »
hey everyone,
           can anyone tell me where i can get the clutch kit with the fly for a half decent price lol. and where do i find the engine code cheers
2** Bhp, 2** Lb/ft , R-Tech map, FMIC, Forge CL007P, Powerflow Cat-back, 18" Tsw pace, Eibach -40mm springs, Pipercross induction kit, vr6 Clutch g60 flywheel
Offline Jamm89
  • Mk4 GTI 2ltr 3door Black
Re: clutch!!!!!
« Reply #1 on: 02 August 2008, 16:17 »
Its in the manual or in the spare wheel well.  :smiley:
Offline richw911
Re: clutch!!!!!
« Reply #2 on: 02 August 2008, 17:54 »
hey everyone,
Hello welcome, As said in the spare wheel compartment white sticker left hand side or under the plastic engine cover left hand side of engine.
What size engine do you have? Derv or petrol?
« Last Edit: 02 August 2008, 18:09 by richw911 »
Offline stealth_gti
Re: clutch!!!!!
« Reply #3 on: 02 August 2008, 19:07 »
 its the 1.8 turbo mate, year 2000 iv seen this one what you thing for the top one clutch and fly   http://www.eurocarparts.com/ecommerce/Search_Results.asp
Offline richw911
Re: clutch!!!!!
« Reply #4 on: 02 August 2008, 19:14 »
prob be an AGU engine  :wink:  link not working?
Im in the process of doing my 1.8T clutch and im doing the G60 flywheel and VR6 clutch :afro:
« Last Edit: 02 August 2008, 19:16 by richw911 »
Offline stealth_gti
Re: clutch!!!!!
« Reply #5 on: 02 August 2008, 19:17 »
would t be worth me doing that what sort of gains do you get from it.  :smiley:
Offline richw911
Re: clutch!!!!!
« Reply #6 on: 02 August 2008, 19:27 »
I dont think you get much gain TBH But the G60 flywheel is lighter  :wink:
The main reason people do this is it can handle more power than the standard dualmass set up. Ideal if you have remap etc.
 Also you should change the dual mass flywheel when you do the clutch- IIRC the dualmass is about £250 :shocked:
The G60 single flywheel is £130 :afro:
« Last Edit: 02 August 2008, 19:30 by richw911 »
Offline stealth_gti
Re: clutch!!!!!
« Reply #7 on: 02 August 2008, 19:32 »
ill do that then  because iv got the car booked in at the end of this month for a revo remap iv got a fmic, and sports cat sat here waiting to fit to, so would probably be better of fitting that.
is it easy what parts exactly do you need
        cheers
Offline richw911
Re: clutch!!!!!
« Reply #8 on: 02 August 2008, 19:37 »
        cheers
You need - G60 corrado flywheel -bolts MK3 golf VR6 clutch and bolts.
I will do a sticky with all the part numbers soon  :wink:.
Have a look at this : http://uk-mkivs.net/forums/t/186276.aspx :afro:
Offline stealth_gti
Re: clutch!!!!!
« Reply #9 on: 02 August 2008, 19:47 »
yea if you could do that mate i think it would be a massive help to alot of people. parts and part numbers for the complete swap cheers scott
