Author Topic: bought a 1.8t help  (Read 3128 times)
Offline chasmk11
bought a 1.8t help
« on: 29 April 2004, 20:11 »
Got a mk11 gti8v 87
Just got a audi 1.8t with box and loom/ecu. Not sure what else i need
i.e hubs, engine mounts, gear linkage
Any advice and tips would be appreciated :)
marcus123
Re:bought a 1.8t help
« Reply #1 on: 29 April 2004, 22:14 »
how much did u get it for mate?
Offline chasmk11
« Reply #2 on: 29 April 2004, 23:19 »
?1000 the lot including dash  ;D
Just gotta work out what else i need to get her in the golf
Offline Dizzie
  • Make friends with your fast
« Reply #3 on: 29 April 2004, 23:58 »
a set of G60 brakes wouldn't be a bad idea.  ;)
you'll probably need a set of clocks and the key as the imobilser is built into them.
Offline RandomJord
« Reply #4 on: 30 April 2004, 01:33 »
did i mention i just got an S4 engine?   ;D ;D ;D ;D ;D
Skoda Octavia VRS DSG (soon!)
Skoda Rapid Spaceback
An a Signum for towing me old caravan!
marcus123
« Reply #5 on: 30 April 2004, 08:44 »
yeh i got a reply for you mate on your thread chief,
so wat was your 1.8t out of mate?
thats an absolute steal to get all of that mate! :D
Offline chasmk11
« Reply #6 on: 30 April 2004, 09:28 »
hey dizze i see you have a 20vt in your (sweet) mk2 did you have to move any mounts or do any strenthening. also what box did you use ?
Offline Dizzie
« Reply #7 on: 30 April 2004, 22:37 »
I have the engine, but it's going in the tuesday after Inters. From what I've read online about the 20vT swaps the engine mounts are all the same apart from 1 that you'll need of a mk2 engine mount for one of the back ones. I'll try and find out which.
Mine's a Audi TT lump so obviously (unless I have a secret rallye/syncro project going on) I won't be able to use the TT's box so we're using a mk4 20vT one.
Strengthing isn't needed as far as I know. I'm going to invest in some strut mounts to tighten up the cornering though. they look cool too :)
Take lots of pics if you're doing this yourself. :)
good luck
marcus123
« Reply #8 on: 30 April 2004, 22:40 »
hmmmmm dizie,
wats the project you have got underway?
mines underway too :D------------>project g60! :D
Offline chasmk11
« Reply #9 on: 01 May 2004, 22:14 »
dizze i spoke two bedrock veedubs in scotland and they said if i get a g60 rear mount it will fit the rear engine/box mount on the back
They also sugguested a passat h-m reg pedal box as the clutch is hydraulic and ours is cable
Let us know if you find anything else out of interest,
i :D
