Author Topic: ticking sound  (Read 2619 times)
Offline mo_utd
ticking sound
« on: 31 July 2008, 21:32 »
Hi ppl. i got a 1.8 gti 16v which i bought recently. the problem is that its developed a ticking sound, when i rev the engine it ticks faster, sometimes it gets really loud. does anyone know what the problem is? Please help!!!
Offline harryc
Re: ticking sound
« Reply #1 on: 31 July 2008, 21:37 »
Where abouts is the noise coming from? Cylinder head?
Offline mo_utd
Re: ticking sound
« Reply #2 on: 31 July 2008, 21:43 »
near the cam belt or it maybe the cylinder head?
Offline mo_utd
Re: ticking sound
« Reply #3 on: 31 July 2008, 21:46 »
went to 2 mechanics. one said that the engine is tired, which is bulls**t because its done 150k on the clock with full service history and the other said something about the power steering.
Offline DarnPB
  • Formerly Darnpistonbroke
Re: ticking sound
« Reply #4 on: 31 July 2008, 22:46 »
Listen carefully to the ticking sound and try to determin the speed. Is it regular and about half engine speed? If so it could be a hydraulic tappet getting lazy. If it is more like a heavy knocking sound coming from the depths of the engine, then you may have big end bearing issues. Check the oil level, or even give it an oil change to see if that makes a difference.
Offline Conker
Re: ticking sound
« Reply #5 on: 31 July 2008, 22:58 »
Just a thought... Check the cars history for when a cam belt & tensioner change was last done - Perhaps the tensioner pulley is worn?
 :undecided:
Offline mo_utd
Re: ticking sound
« Reply #6 on: 31 July 2008, 23:46 »
the power steering belt, fan belt, cam belt tensioner stud, cam belt tensioner and the cam belt were all done back in last december.
Offline Khare
  • The bear that khares
Re: ticking sound
« Reply #7 on: 01 August 2008, 11:52 »
i'd take a guess at something like cambelt tensioner and cambelt. Check the cambelt isnt hitting the plastic cam cover or the metal sheet on the other side. Im telling you cos i had it before.
Offline russ-vdub
  • Once a Dub, Always a Dub
Re: ticking sound
« Reply #8 on: 01 August 2008, 12:20 »
I'd say thats a tappet failure by all accounts. 150,000 is about the time they start to die. Oil change will definately help this quiet down.
Offline Benrevs
Re: ticking sound
« Reply #9 on: 01 August 2008, 17:04 »
Could be a lairy injector, I had to replace one of mine because it got that loud!  Speaking of injectors, does anyone know what colour should be on the 1.8 diji?  I have a mk3 block and I have yellow... sure this isnt standard??
« Last Edit: 01 August 2008, 17:06 by afghan socks »
