Author Topic: Fitting Big Bumpers to MK2  (Read 2952 times)
Offline Greig
« on: 29 April 2004, 16:47 »
when fitting Big Bumpers to a MK2 do you need new wiring looms or can u just use the originals from the small bumpers???
most companies that supply big bumpers give u wiring looms but GSF car parts dont have them so i need to know before ordering.
kniterider
Re:Fitting Big Bumpers to MK2
« Reply #1 on: 29 April 2004, 16:52 »
the only extra wiring you will require is for front fog lamps (if you buy them), this should plug into the factory loom some where i think, youll also need brackets to hold foglamps in place so the sit correctly behind the bumper(you should get these if you buy lamps), as for the indicators etc the original small bumper wiring should be ok
(dont talk to me about fog lamps!!!! lol)
Gaz 8)
« Last Edit: 29 April 2004, 16:53 by kniterider »
Offline Greig
« Reply #2 on: 29 April 2004, 17:10 »
thanks mate i'll take your word for it i'll go ahead and order them but if i run into any trouble with the good advise u gave me there will be hell to pay got it!!!! lol
Veedubgt18v
« Reply #3 on: 29 April 2004, 17:25 »
you will need to extend the wires to the indicators cos they arent long enough, you will also need 90 spec indicator lenses
Blue MK2
« Reply #4 on: 29 April 2004, 17:40 »
try GPC before buying the kit. you could probably get a deal or something and are genuine parts...
http://www.gpcvwaudi.com/
Offline Dizzie
  • Make friends with your fast
« Reply #5 on: 30 April 2004, 00:01 »
I'd strongly advise buying genuine from GPC. A LOT better fit than the aftermarket kits.
on this subject check out this month's Revs mag at that 5dr mk2. the fit on his bumpers front and back is awfull! That RS4 front bumper doesn't fit anywhere near as good as the old big bumpers we run. Same really.
