Author Topic: stutter at around 70 between 3-3.5k revs  (Read 2976 times)
Offline spacerat
Re: stutter at around 70 between 3-3.5k revs
« Reply #20 on: 20 September 2008, 00:36 »
yep, thats where the broken wire was coming from on mine,
Offline adihodgson
  • DUB......Deuchland's ultimate benchmark
« Reply #21 on: 21 September 2008, 17:09 »
I have the exact same problem on my 8v, same speed, revs & 5th gear. Plugs, leads etc have been changed, tune & session on rollers but still there. Treid unplugging the lift pump in the boot, changing ecu & fuel pump relays but still the same. Waiting for Volkswizard to send me a replacement dizzy as the hall sender may be faulty.
« Last Edit: 28 September 2008, 20:08 by adihodgson »
Offline adihodgson
« Reply #22 on: 28 September 2008, 20:10 »
Changed the dizzy today & the car now seems fine.......did 8 runs at 70mph in 5th & no juddering just pulling really well. Maybe you guys should give this a try......good luck.
