Author Topic: stutter at around 70 between 3-3.5k revs  (Read 2975 times)
Offline Simpson
  • one day il learn
Re: stutter at around 70 between 3-3.5k revs
« Reply #10 on: 01 August 2008, 22:47 »
yeha was just thinking im going to clena the throttle body out tomorrow, il let you know, have you checked the dizzy is advancing properly? i could be barking up the wrong tree though  :smiley:
i must buy a new car!
Offline danny_p
« Reply #11 on: 01 August 2008, 23:12 »
dose it do it at full throttel,    if it starts playing up and if you floor it dose it sort itself out ?   if so i would have a look at the airflow meter.
all the VW's have gone bar 1.
Offline Simpson
  • one day il learn
« Reply #12 on: 03 August 2008, 15:22 »
no it does it when you take your foot off then put it down again and if you accelerate out of it its fine, i have since changed the afm, whhich (fingers crossed) has worked. Cheers for input alos put some Forte gas cleaner in the tank hope that helps.  :smiley:
Offline Diluxe
« Reply #13 on: 03 August 2008, 15:26 »
I used to have this problem on my 16v , oil would make its way down the dizzy shaft & mess with the hall sender, i used to pull it off every other week give it a godd spraying with WD40 , till i got fed up & bought new/recon unit of ebay , never had the problem again.
1997 16V
Offline iddlesgti
  • one way ................. dub way
« Reply #14 on: 03 August 2008, 16:52 »
hi simpon just a idea mine did this also!
have you got a KandN stylee air cone thing if you have try the standard airbox back on.
mine was terrible until i changed mine back!
Offline Simpson
  • one day il learn
« Reply #15 on: 03 August 2008, 21:40 »
i have a drilled arbox, would this affect it?  :smiley:
Offline spacerat
« Reply #16 on: 03 August 2008, 23:49 »
no not had anything checked properly yet, my mates a mechanic thou and his gonna take it in to work for me and check it all out with all the garages electronic stuff.
Offline spacerat
« Reply #17 on: 18 September 2008, 23:02 »
did u ever sort the problem out?  i did last weekend, turns out that a wire that goes somewhere near the throttle body had snapped,  i wired it back up and its running perfect,
Offline Mr Blue
« Reply #18 on: 18 September 2008, 23:25 »
My digifant would judder and then cut out at junctions. The idle revs would drop real low.
I just swapped my MAF sensor for a good one.
« Last Edit: 18 September 2008, 23:29 by Mr Blue »
Offline Donuts
« Reply #19 on: 19 September 2008, 09:35 »
I had a very similiar problem which was caused by a faulty ignition control unit. I'm not sure that I've used the proper name for it. Anyway, its found in the top left hand corner of the engine bay. There's a pic at this address:
http://www.autopartswarehouse.com/images/product_images/thumbs/WORLDPAC/W01331621417HUC.JPG
