Author Topic: DV Valve  (Read 7006 times)
Offline pridders
  • Pearl Black 5 Door DSG GTI 05
DV Valve
« on: 30 July 2008, 11:06 »
Hi All,
As some of you may have read I have recently had the Stage 1 Revo fitted and I am very impressed. Jim at JKM has told me that the boost psi is slightly lower than he would like and will be affecting the BHP. He said this could be caused by slight damage to the DV valve and would need to check it to be sure. Unfortunately I would have had to wait a couple of hours to have them check it out and I needed to go. I now need to get the old one off to check it and may as well replace it with a new stock DV valve. Jim has also said that sometimes the psi can be down and nothing to do with the DV valve but the ECU sorts it out over a couple of weeks. He could not explain why just cleaver engineering/electronics on the cars these days.
Anyone else had this problem? To be honest it doesn't feel like its lacking any power and cant imagine what it will be like if I get some more! :evil:
Anyone know the part number for a stock DV valve? I think there about £30?
Offline topher
  • Administrator
  • fully functioning
Re: DV Valve
« Reply #1 on: 30 July 2008, 11:31 »
If you're taking it off anyway, might aswell upgrade to a Forge one that uses a piston instead of a crappy plastic diaphragm :grin:
Offline joesgti
Re: DV Valve
« Reply #2 on: 30 July 2008, 11:37 »
hey mate, get the forge valve, its much stronger than the OE one. I was lacking boost, 8psi to be exact but i dont think youl be that bad  :laugh: i had split hoses on my dv. then my car wasnt boosting past 5krpm so re-flashed the ecu and put a new map on and everything is sorted.
did JKM  say how much boost you were loosing? probs wont be the dv as when they go or split you would defo know about it  :smiley:
GTI MK5
Not the only GTI...........but the best! ; )
Offline Hurdy
Re: DV Valve
« Reply #3 on: 30 July 2008, 13:29 »
I can highly recommend the Forge DV, amongst lots of other mods on my motor :grin:
Seat Leon Cupra Black 290 DSG
Offline RedRobin
Re: DV Valve
« Reply #4 on: 30 July 2008, 22:31 »
....The stock DV is well known as a potentially weak link, especially on remapped GTI's. A friend has been through 3 stock DV's on his MY04 GTI. The Forge DV is very robust and also holds boost better I'm told. JKM fitted mine - It's tricky because of where it's located.
Offline Greenouse
Re: DV Valve
« Reply #5 on: 31 July 2008, 09:28 »
How easy is the fitting on an ED30 John Hurdy? Obviously located in an easier location, but just wondered whether it was a garage or DIY job?  :huh:
Offline joesgti
Re: DV Valve
« Reply #6 on: 31 July 2008, 09:36 »
i did mine my self and mines under the car, i do not suggest doing it yourself if its located next to the turbo  :smiley:
GTI MK5
Offline Hurdy
Re: DV Valve
« Reply #7 on: 31 July 2008, 09:38 »
I had it fitted at Awesome and they put it on in 30 mins. You have to take off the engine cover to get the piping fitted, but it is miles easier than the standard GTI. I'd definitely fit my own next time. Forge even have a download on their site for fitting and tips :cool: - you just have to ignore where they want to fit it as it is for the standard GTI location.
Offline MAT ed30
Re: DV Valve
« Reply #8 on: 31 July 2008, 09:39 »
its easy just unbolt old one and cut pipes to right legth and then bolt it all back on with new switch that comes with it and make sure its out the way ot the fans.
EDITION 30 NUMBER:- 1038 ,Forge dv,ecs dog bone insert,Tints,inpro smoked indicators,panel filter,Black badge,Black roof,Black wing mirrors,REVO stage 2,Blueflame TBE,neuspeed arb,Neuspeed drop links,KW V3,S3 Intercooler,VWR clutch and LSD,VWR 6 pot brakes,1956 vw beetle (2332cc)
Offline Rob-MK5
Re: DV Valve
« Reply #9 on: 31 July 2008, 09:40 »
Heres my old DV,
