Author Topic: Gamma Radio codes/ Removal  (Read 9708 times)
Offline GTi-Matt
« on: 29 July 2008, 22:13 »
Anyone that has the standard head unit set-up (gamma) that came with the vehicle you wont need a radio code if you disconnect the battery, the radio will sense that its in its rightful car and re-code itself.
If not take a trip to VW and thay will tell you what the code is for future reference for free.
To Remove:
You need to removal keys Thay can be purchased from halfords for £3.99
You need the Euro ones.
Put the keys into the 2 slots with the hooks facing outwards and pull out.
« Last Edit: 15 April 2009, 19:09 by richw911 »
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
jamie16v
Re: Gamma Radio codes/ Removal
« Reply #1 on: 04 April 2012, 11:16 »
I'm not sure if it will resync if you have swapped your clocks or altered the dump file in your clocks. Just my reckonings
