Author Topic: advise on new turbo please  (Read 3860 times)
Offline Cosworth Lee
« on: 27 May 2008, 16:45 »
Hi,
last week the golf gt tdi lost all boost. checked the obvious pipes and electrical conections. seem ok.
i call VW up to ask for a vag com, and they want £100. so i thought sod that, i'll have a look at the turbo shaft first.
anyway long and short of it is i ended up taking of the entire inlet and turbo/manifold.
there is a lot of crap (almost 1/8" of oil/gunk) caped to the inside of the inlet manifold and the connecting valve. tho it has done 117k miles!!
also the intercooler pipe was oily. anyway
the turbo shaft will not spin freely and is very sooty.
there seems to be a very small flat spot on turning, but i think this may be the sh!t inside on the vanes.
also the actuator rod is locked solid!!
anyway took it to a turbo place they want £385 +vat (so about £450) to recon my turbo?
they also reckon they cant supply an actuator seperatly.
so my question is do i get them to completly overhaul the turbo. or do i look at finding a 2nd hand one, or an aftermarket one.
bear in mind im probably going to sell the car towards the end of the year so dont want to go crazy.
id apreciate ur help, as the wifes using the escort cossie, to go to work at the mo, and that is a scary thought!! :cry:
Offline christianduncan
Re: advise on new turbo please
« Reply #1 on: 06 June 2009, 22:56 »
yes, im having the same problem.  i need my actuator cleaning.  can you help me with how to do this? have you got any manuals avaliable? HELP PLEASE  :smiley: :smiley: :smiley:
Offline Steve_PD
« Reply #2 on: 07 June 2009, 15:00 »
Forge sell an actuator for around £110, not sure if it will fit you turbo  :undecided:
« Reply #3 on: 07 June 2009, 17:20 »
ow ok where do i check this out from mate?
thanks  :smiley:
Offline Steve_PD
« Reply #4 on: 07 June 2009, 18:02 »
What engine you got????
« Reply #5 on: 08 June 2009, 12:20 »
its the 1.9 gt tdi, 110bhp 5 speed box ...
thanks
Offline Steve_PD
« Reply #7 on: 08 June 2009, 16:46 »
ok mate thats great where abouts is it? im not that clued up just yet im still learning.  im was going to try cleaning mine 1st.  what you think?  :smiley:
Offline Steve_PD
« Reply #8 on: 08 June 2009, 17:23 »
Dont know how your going to clean it, plus if the actuator is clogged up chances are the turbo is going to be.
see if you can move the actuator rod backwards and forwards
« Reply #9 on: 08 June 2009, 20:08 »
ok mate, as i said ive not a clue really, im use to petrol engines :-), were abouts is the rod that i need to check?
thanks
