Author Topic: Passenger Side window problems!  (Read 1558 times)
Offline nickbluegti
« on: 27 May 2008, 09:36 »
Over the weekend the passenger side window was going up at normal speed until it had about a third to go then went really slowly but still closed. On sunday it went slowly then stopped and I had to lift it a litttle bit for it to grab luckily it closed al the way but now I dont want to open the window in case it drops completely.
Could this be a window regulator problem or has somebody else had this and knows what its likely to be? if you have any idea oin cost to repair or if the stealers are the best to fix it or take it to my local garage?
Offline GTi-Matt
Re: Passenger Side window problems!
« Reply #1 on: 27 May 2008, 09:48 »
sorry to hijack this thred but mine goes up fine but when it gets to the top it creaks for ages and none of the other windows do it :undecided:
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline Rhyso
« Reply #2 on: 27 May 2008, 10:27 »
deffo sounds like the clips - get it sorted before it disappears completely!
Offline GTi-Matt
« Reply #3 on: 27 May 2008, 10:51 »
on mine or nicks?
Offline nickbluegti
« Reply #4 on: 27 May 2008, 18:22 »
its booked in to get the regulator/clips sorted. was definately the clips. Bloody girlfriend let the window down to let a bug out and then it wouldnt go up then dropped in to the door! didnt drop from far though so at least the glass is intact.
