Author Topic: Oil consumtion on GTI  (Read 4544 times)
Offline 182_blue
Re: Oil consumtion on GTI
« Reply #10 on: 27 May 2008, 10:58 »
....The Mk5 GTI is well known for drinking oil in her first few thousand miles/km. Don't worry too much - She'll settle down. She's a bit of a slapper....Likes to have a drink to get herself going! :evil:
mine must be broke as its not drank anything !
....But don't let her get as dry as a nun's nasty!!
i wont, but from the dipstick alone it doesnt appear to have moved, perhaps i sealed the rings properly  :evil:
ps at what stage does the oil light come on ?
Offline Hurdy
« Reply #11 on: 27 May 2008, 11:04 »
The oil light comes on when the dipstick level is just on the last few mm. Well below the minimum level for topping up.
I've only once had to top up between services and that was with about 1/2 a litre after 5 k miles. The advice you got on topping up seems way, waaaay over the top.
Seat Leon Cupra Black 290 DSG
Offline 182_blue
« Reply #12 on: 27 May 2008, 11:10 »
^ good to know, but i cant remember ever having to top a car up with oil, dont know what im doing wrong  :laugh:
Offline neg
« Reply #13 on: 27 May 2008, 11:59 »
VAGCOM tells you your current level in mm and the warning level - which I 'think' was 47mm but dont hold me on that, I was browsing through the different blocks the other day and noticed it - could be useful  :smiley:
Offline Hurdy
« Reply #14 on: 27 May 2008, 12:01 »
Hi neg,
47mm reaches to where on the dipstick?
Offline block
« Reply #15 on: 27 May 2008, 12:14 »
Mine used about 4 top up tubs in the first 14k miles, which i put down to dsg redlineing it often if you stamp on the gas. when driven on the paddles and not quite reving the nuts off it, it uses less oil. Is yours a dsg?
GTI Mk7 5dr, PP, Nav, Red.
Offline neg
« Reply #16 on: 27 May 2008, 12:23 »
Hi neg,
This reading was down as a 'warning level' so if it hits this the warning light illuminates - which could be just below the dipstick min reading -
I think mine was reading about 58mm (on idle) and I topped it up the other day.
These numbers are from memory, I'll double check when I plug it in again.
Offline john_o
« Reply #17 on: 27 May 2008, 12:46 »
Manufacturer limits are always silly so that you cannot claim on anything but a 'due to expire' engine  :grin:
Should run a E39 M5, now they use oil as much as fuel and its normal  :huh:
Sounds like the dealer underfilled in the service , esp if you never saw the light before.
Obv check for serious leaks too!
Using oil (esp during running in) is not a bad thing , I guess its changing oil usage habits you should worry about.
I ran mine in 'vigorously' and expected some usage but its been next to nothing so far. (8k)
Let it warm up , thrash it , and check regularly  :cool:
Black 3dr Edition 30 manual
DEFi boost gauge | ECS Dogbone | WLineAntiLiftKit
Offline sharman
« Reply #18 on: 27 May 2008, 18:22 »
Rang Volkswagen direct today to query oil consumption. Their technical dept told me the GTI will use around 1 ltr oil per 621 miles! I tried to book car in at National tyres as they were advertising oil (castrol edge) and filter change for under £30. I couldn't even buy the oil for that! Unfortunately, The most annoying stroppy employee of National refused to do my car (something to do with unable to get an oil filter). He also tried to say I'd need VW oil, and when I explained castrol edge was suitable, he basically called me a liar. I was told to go to Halfords and not to bother them! Anyway, off to Halfords to part with £44!
Life is not a rehearsal, live it.
Offline 182_blue
« Reply #19 on: 27 May 2008, 21:32 »
seems a lot to me
