Author Topic: Mk 2 power steering pump  (Read 1057 times)
Offline perryqhill
« on: 25 May 2008, 14:10 »
Finally got round to looking at my power steering pump (was going to renew the oil and put a genuine VAG belt on) and found this:
The bottom inside flange where the bolt goes through the pump has sheered/snapped off.
I haven't took it fully apart yet, but does anyone know if this is part of the pump or it's just a seperate but to keep the power steering pump in place?
Offline Uruk Hai
Re: Mk 2 power steering pump
« Reply #1 on: 25 May 2008, 14:25 »
Thats one of the two points that alow the pump to moved to adjust the tension of the belt and although I'm not sure I think it is part of the pump, was the belt slipping at all ?
Offline perryqhill
« Reply #2 on: 25 May 2008, 15:32 »
The belt was making a horrid 'croaking' type noise, not really slipping.
When I got the car it had just been fitted with a replacement second hand one, there's been a few bolts came out and became slack - so I replaced them. Today I was trying to cure the problem by changing to a geniune VAG belt and changing the fluid, but as soon as I got started that bit dropped out.
Luckily I noticed the bolt above the one which had snapped wasn't even there - so didn't bother changing the fluid or the belt, put a bolt in and done everything up and it seems miles better than it was originally - no croak, nowhine or squeal at all at the moment  :grin:
I'll see how it goes and keep my eyes open for a new pump, but at the moment it seems much much better.
« Last Edit: 27 May 2008, 16:44 by perryqhill »
Offline Uruk Hai
« Reply #3 on: 27 May 2008, 18:09 »
Fingers crossed dude  :smiley:
