Golf mk3
hardmonkeys
8v Stalling Problem Fixed [For Me]
Topic: 8v Stalling Problem Fixed [For Me] (Read 897 times)
adyh
25 May 2008, 13:40 »
I have had the dreaded over run stalling issue. Everything looked ok, then i checked the small pipe that runs from the right hand size of the throttle body. It had perished but you couldn't see it very easily as its braided . I've replaced it and no more problems.
So my advice is double check it if you are having problems.
admc6
Re: 8v Stalling Problem Fixed [For Me]
25 May 2008, 15:04 »
Have you got a picture of the bit you changed?
adyh
25 May 2008, 15:06 »
Ill try and get one , its roughly 6" long and about 5mm wide. mine was black with white flecks on it.
admc6
25 May 2008, 15:12 »
I think i know the one you mean, but would be good to see what the damage was like
adyh
25 May 2008, 15:17 »
Visually it looked ok , it was only when you looked very closely that you could see that it had, had it. I pulled it off and the car stopped stalling , but felt under powered. Give it a try.
Golf mk3
hardmonkeys
