Author Topic: xenon upgrade kits  (Read 2695 times)
Phil mcavity
xenon upgrade kits
« on: 24 May 2008, 19:58 »
Anyone seen these on offer, rather cheaper then the real deal but as good as.
Do u have to have headlamp washers installed by law if you fit one of these???
thoughts anyone?  cheers  :smiley:
http://www.novablue.co.uk/upgrade-kits.html
Offline 182_blue
Re: xenon upgrade kits
« Reply #1 on: 24 May 2008, 20:01 »
there was alot of debate on another forum about legalities, but i guess come MOT time they can be removed if needed, i do however prefer the look of proper zenons
Offline 182_blue
« Reply #2 on: 24 May 2008, 20:04 »
Offline 2007GTI
« Reply #3 on: 24 May 2008, 20:18 »
One word, illegal. About a year ago there was debate on here, heavily involving TT totally blowing anyone out of the water who claimed they were legal.
You are correct you do need headlamp washers, but crucially you need a factory fitted auto leveler fitted to the rear axel.
Don't touch them with a barge pole.
Offline TagnuT
  • Edition 30
« Reply #4 on: 24 May 2008, 20:19 »
interesting video here http://www.autoexpress.co.uk/videos/featuresvideos/204742/xenon_test.html
Interesting Vid: When TT used to be on here he was dead against fitting kits like that. There have been a few posts on here over the last 12 months regarding fitting HID bulbs.
Bye Bye Edition 30
Offline RedRobin
« Reply #5 on: 24 May 2008, 20:21 »
....Good Autoexpress vid, blue :smiley:.
Obviously the authorities should make such HID lights both illegal and illegal to sell them.
Offline 182_blue
« Reply #6 on: 24 May 2008, 20:27 »
i would say such kits are fine for the driver, giving better light etc, but for other road users they could be an issue
Phil mcavity
« Reply #7 on: 24 May 2008, 21:50 »
just on this, this was an advert in good old VWDRIVER mag!!, so nice to see theyre printing illegal adverts if thats what your all saying????
page 61 May issue
Surely Vw wouldnt print something like this in their own magazine?????   :angry:
Offline richw911
Offline 182_blue
« Reply #9 on: 24 May 2008, 22:03 »
Therefore a HID headlamp unit sold in the after market should:
1. be type approved to ECE Regulation 98 as a component.
2. when fitted to the vehicle should enable ECE Regulation 48 to be complied with (although no government inspection will take place).
3. Comply with RVLR as far as "use" is concerned.
In practice this means:
1. The headlamp unit (outer lens, reflector, bulb) shall be type approved to ECE 98 and be "e-marked" to demonstrate this. That can only be done by the headlamp supplier - Hella, Valeo etc. who must test the headlamp in an independent laboratory.
2. Once fitted to the vehicle it must have headlamp cleaning and self-levelling (which can be for the headlamp or can be in the vehicle suspension - some expensive estate cars have "self-levelling suspension" and that is adequate). Also the dipped beam must stay on with the main beam.
3. The headlamp must be maintained in good working order, kept clean, and aligned/adjusted correctly like any other headlamp.
Under the Road Traffic Act 1988 it is an offence to supply, fit or use vehicle parts which are not legal.
In summary it is not permitted to convert an existing halogen headlamp unit for use with HID bulbs. The entire headlamp unit must be replaced with one designed and approved for use with HID bulbs and it must be installed in accordance with the rules stated above.
