Author Topic: Inner CV Gaiter Question  (Read 1454 times)
Offline leegt5
« on: 24 May 2008, 10:17 »
My Drivers side inner CV gaiter is split and I have the mot in a week.... My question is do I need to drain the gearbox oil to pull the drive shaft from the gearbox to change it ??
I have done outer cv gaiters before but never the inner one.. Is it a pain in the arse or not too bad ???
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Inner CV Gaiter Question
« Reply #1 on: 24 May 2008, 10:20 »
They unbolt with the 8 hex bolts on these, there is no need to drain the fluid.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline leegt5
« Reply #2 on: 24 May 2008, 10:30 »
Thats what I wanted to hear !! Cheers
Offline krave
« Reply #3 on: 24 May 2008, 15:02 »
A 12point spline is what you will need. Or at least it is on my vr6.
Offline beni-iow
« Reply #4 on: 24 May 2008, 16:43 »
if i rember rightly the inner gater is not a mot faliure
Offline boyt
« Reply #5 on: 24 May 2008, 21:53 »
inner gator isnt a failure, outer is
andy
