Author Topic: Turbo oil feed  (Read 746 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Turbo oil feed
« on: 23 May 2008, 01:39 »
Hi, im still faffing about with my AEX 1.4L engine trying to get a turbocharger system setup for it.
I helped a freind do this a while back with used parts for a laugh and it was a success! but i want to do it properly and turbo my 1.4  :grin: it will do untill i get a new engine sorted,  its purly for the experemental side not the power before you all tell me to get a VR6  :laugh:
Does any one know how you go about geting an oil feed for the turbo.  I know the dran can go back into the sump somehow but where can i get oil pressure from the engine?!?  :smiley:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Pete Taylor
Re: Turbo oil feed
« Reply #1 on: 24 May 2008, 17:40 »
how about a sanwich plate for the oil filter and run a feed off there, through the turbo, then through a small oil cooler then back into the sandwich plate?
Offline Rmachines
Re: Turbo oil feed
« Reply #2 on: 24 May 2008, 22:49 »
Ahh, never thought of that,  I will see if i can get hold of one to fit, with any luck i will be able to get started on this little project  :wink:
