Golf mk3
hardmonkeys
Immobiliser???
Topic: Immobiliser??? (Read 969 times)
dub268
Guest
Immobiliser???
23 May 2008, 00:43 »
Does anyone know if factory immobiliser where fitted to the 1994 8v GTI? if so which wires do i cut
im have major problems getting car to start, i can turn my key and ill get no power to anything on dash but can hear fuel pump priming and get a click from the fuse box area but car will turn over as if it wants to start, others times dash will light up with all the normal lights pump primes and get the clicking sound from fuse box but car wont turn over, if any one can help that would be great
Rmachines
Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Immobiliser???
23 May 2008, 01:45 »
you sure thats the immobiliser? ? Mine cuts the fuel pump! the car will start but cuts out as the fuel pump doesnt run
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
dub268
Guest
Re: Immobiliser???
23 May 2008, 10:23 »
im just going through process of limitation at the min ie new relays, HT leads and spark plugs, im not even sure i have a immobiliser on car, if there is no immobiliser can anyone suggest anything else that could cause this to happen
Vdubbster
Re: Immobiliser???
23 May 2008, 10:38 »
Starter motor?
Rmachines
Re: Immobiliser???
23 May 2008, 10:44 »
no you would get dash lights if its the starter. its a bit odd. probably just a loose wire or something but i cant think what it could be at the moment.
dub268
Guest
Re: Immobiliser???
23 May 2008, 18:54 »
i was thinking starter motor as well i think that will possible be next thing to replace. just out of interest a worn key would that cause any problems in the ignition barrel at all?
Golf mk3
hardmonkeys
Immobiliser???
