Author Topic: Do you still use V-power/Ultimate  (Read 5407 times)
Offline neg
Re: Do you still use V-power/Ultimate
« Reply #10 on: 23 May 2008, 10:15 »
Does anyone use 95 RON? If so, how does the car run?....i dont want to either but the costs are becoming insane up here.
Your car wont run aswell, wont run badly though.  You may see a slight drop in performance and lower MPG as lower RON means the FSI part of the engine isnt running at its best.
Offline AlanD
  • MK5 2.0T 16v
« Reply #11 on: 23 May 2008, 11:34 »
Mine is using the 95 stuff most time and it runs fine.
Offline gazbutmk5gti
« Reply #12 on: 23 May 2008, 11:37 »
It will run fine, but you won't get the best performance or economy from it. If you look in you fuel flap it recommends superunleaded
Revo stg2+ & lots more
Offline AlanD
  • MK5 2.0T 16v
« Reply #13 on: 23 May 2008, 11:38 »
Yeah, seen that, but my wallet recommends 95 :D
Offline john_o
« Reply #14 on: 23 May 2008, 12:06 »
Its a performance car so stick in the good stuff  :cool:
Its the car I've seen the biggest difference between 95/97 and 99 fuels , 99 really is soo different.
Turn your air con off and thatll make up the diff between the costs ;-)
although thatll be lost as soon as you hoon it
Black 3dr Edition 30 manual
DEFi boost gauge | ECS Dogbone | WLineAntiLiftKit
Offline bacillus
« Reply #15 on: 23 May 2008, 13:44 »
using 95 ron fuel will be counterproductive as you'll get less mpg and hp compared with 98 ron.
I'm still using V-Power.
Without traction power is nothing!
Offline Russ.C
« Reply #16 on: 23 May 2008, 15:33 »
Yep, mines never had a drop of anything else but V-Power.  :smiley:
GTI Edition 30, 3Dr, Manual, Black Pearl, Xenons, Ipod, Highline, Rear Tints & Superchips Bluefin ;)
Offline SteveS
  • GTI ED30
« Reply #17 on: 23 May 2008, 15:44 »
tesco 99 for me
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline bobotheclown
« Reply #18 on: 23 May 2008, 16:09 »
how much is tesco 99/shell v-power around where you guys live?
Offline G864 TST
« Reply #19 on: 23 May 2008, 16:10 »
V Power from day 1, only the best fuel for the best car
CT
