Author Topic: Pops when ease off throttle  (Read 3336 times)
Offline Jay
  • balding fat cvnt
Re: Pops when ease off throttle
« Reply #10 on: 22 May 2008, 20:09 »
PS my car pops and bangs like a machine gun  :laugh:
It's cos u in da hood sista  :cool: blap blap blap yeah!
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #11 on: 22 May 2008, 21:30 »
Jay......You have seen where I live in Milton Keynes, with my car sounding the way it does i really fit in on my estate  :grin:
Offline MarkS
« Reply #12 on: 22 May 2008, 21:47 »
Its brap! Not blap
Mannnn you're well not from da hood!
 :grin:
My car pops too on the down changes.
Don't think it will cause any real problems?
Makes me look gangsta though  :smiley:
I've got the standard chip in there as far as I know
Offline cняis
« Reply #13 on: 22 May 2008, 22:46 »
dis the idle ok? if the car goes to stall at junctions etc it is probably an air leak.
Offline Khare
  • The bear that khares
« Reply #14 on: 22 May 2008, 22:57 »
popping is just unburnt fuel in the exhaust system. When this fuel comes to contact with a hot spot on the exhaust, ie manifold. it explosed causing the pop. It can damage the system (creat a hole somewere) if its standard exhaust, as its weak. If you have a full stainless steel exhaust system then it will resist the hot fuel and be fine. popping is cool, we all agree, but because the car is being overfuelled then you will get less MPG. Thats the only drawback really.
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #15 on: 23 May 2008, 09:46 »
^^ Real sound explaination
Offline Agreeable Slick
  • Unit
« Reply #16 on: 23 May 2008, 14:14 »
See Second post.  :tongue:
Offline Conker
« Reply #17 on: 23 May 2008, 20:16 »
Yep, mine had a popping frenzy a while back and it was because my ignition timing was bolloxed up.
Offline Organisys
  • Old and Slow...
« Reply #18 on: 23 May 2008, 20:51 »
On Digifant cars, check the blue temp sender. Wait for the car to be at temp, then disconnect it. If the engine note changes it's ok. if not it's bust, get a new one.
Offline Khare
« Reply #19 on: 23 May 2008, 21:31 »
i forgot to say.
If the ignition timing is out by a tooth or more, then it will backfire. Get the timing checked and get the fuel mixture set too.
