Author Topic: steam coming out - oil cap  (Read 2101 times)
mjv
« on: 22 May 2008, 08:17 »
hi
i have just recently joined the forum....great to be here !
i have been checking the engine oil levels after using my car & i can see some steam coming out of it when i open the oil cap.
also i have been regularly checking the oil levels and the oil at the dipstick is clean i mean its not dark or with any cr*p like that etc...
now is this steam coming out is normal or is this a problem with the engine???
thanks in advance for your replies.....
cheers... :smiley:
Offline topher
  • Administrator
  • fully functioning
Re: steam coming out - oil cap
« Reply #1 on: 22 May 2008, 09:12 »
Steam would indicate water in your oil, which you don't want. You sure it's not just oil vapour?
mjv
« Reply #2 on: 22 May 2008, 09:39 »
hi
thanks for the reply...
i think its the oil vapour, also i have been checking the oil level (obviously on a flat surface with engine being cooled say 3hrs) and the level its right on top of the chequered area of the dip stick. so its not burning oil i guess.
do you think when the engine is warm the oil will have vapour just like in the kitchen when frying stuff you can see the oil surface does have steam !
pretty sure i dont have water in oil coz i just changed the oil n filter 2 weeks ago
Offline rheady
« Reply #3 on: 22 May 2008, 16:43 »
I'd say it was oil vapour, you don't say if you have checked the oil when the car is cold? If there was a leak you would possibly have oil residue in the water expantion tank.
