Author Topic: Removing rear bumper on MKIV  (Read 1774 times)
Offline Madmax
« on: 22 May 2008, 01:50 »
Hi guys,
I want to remove the bumper on an MKIV so i can touch up some little knicks as it's awkward doing it whilst it's on the car.
Is this a hard/easy job? Only managed to spot 2 bolts & that's it, hope i don't have to remove half the car lol.
Cheers.
Offline gti_copey
  • need...... more.......power!!!
Re: Removing rear bumper on MKIV
« Reply #1 on: 22 May 2008, 15:12 »
its a bit of a nightmare but can be done firstly remove the rear lights by the x3 8mm nuts there is a sneaky couple behind the carpet on both sides where it meets the rear quater (swearing may be required)  :grin:
After taking the lights out you will find 2x 30torx on either side remove them and the 2 underneath and then down the sides holding the wing liner to the bumper you will see 4x 25 torx bolts pretty sure thats it that holds them then its just a simple case of pulling on 1 side and it should pop off disconnect number plate lights and jobs a gooden  :smiley:
GolfGTI.co.uk & R-Tech Summer RR day/Meet Coming Soon - Any excuses and you will be barred
Offline Madmax
« Reply #2 on: 22 May 2008, 22:24 »
Thanks mate, it's only to touch-up some little chips so do you think it's worth taking it off then?
Cheers for the help, i can see myself swearing. :wink:
