Golf mk3
hardmonkeys
location
Topic: location (Read 1066 times)
beni-iow
location
21 May 2008, 20:32 »
hello were abouts are the ecu and fuel pump relays located on the mk3 8v (agg) has any one got any pictures they could take as im gunna do mine and im not sure witch ones they are and i didnt understand the diagrams on the dia thread :embarassed:.thanks
Rmachines
Passat 20vT Estate and Candy White MK3 1.8 GL
Re: location
22 May 2008, 01:50 »
i think the fuel pump has number 99 on it and the ECU as 197 on it. the ECU is bottom row to the very right and fuel pump is the big one with 99 on it
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Pete Taylor
Re: location
22 May 2008, 11:23 »
167 and 30 the numbers are, all the relays are on top of the fusebox, you'll need to remove some trim and pull the fusebox down after unclipping it each side
carlos_r
Just got here
Re: location
22 May 2008, 20:06 »
I too had this problem, it would stall all the time then after a while would cut out totally. Turned out to be the coil sensor pack so the coil was just over heating and cutting the engine. My local garage diagnosed the problem and sorted it out (new coil and coil sensor). It's been running sweet ever since
Rmachines
Re: location
23 May 2008, 01:46 »
hahaha i changed the wrong relay then
I was told it was 99 for the fuel pump
Mabey the relay is still the problem after all
Pete Taylor
Re: location
23 May 2008, 07:37 »
Could well be, it's not the only thing that can cause cut-outs, but it is the most common. Could be the coil, engine speed sensor, or the ignition switch which is getting more common these days
beni-iow
Re: location
Reply #6 on:
23 May 2008, 22:36 »
what is the ignition switch and were is that located?and sorry to sound dumb but why would that cause problems?
Golf mk3
hardmonkeys
location
