Author Topic: vin plate - MK2 Gti  (Read 8464 times)
Offline katana
vin plate - MK2 Gti
« on: 21 May 2008, 19:09 »
Just got hold of 8v Gti for restoration project. Slam panel has been replaced by previous owner but no vin plate. Is the vin number any where else on vehicle ? or How do I get another vin plate ?
Car looks ok except usual rust on arches & sills - will post pictures soon , going to keep "old skool" original
Offline MarkS
Re: vin plate - MK2 Gti
« Reply #1 on: 21 May 2008, 19:29 »
Welcome to the site!
Can't help you with the vin problem  :sad:
However make sure you set up a thread in the project section, as a resto will always make for interesting reading  :smiley:
Offline cняis
« Reply #2 on: 21 May 2008, 20:46 »
vin plate is by the ecu in the scuttle panel drivers side.
Offline dubsport
  • TDI POWAR!
« Reply #3 on: 21 May 2008, 21:11 »
Yeah i was looking for mine today think something funny has been going on with this car as it doesnt have that plate on the slam pannel or under the scuttle pannel clear plastic  :undecided:
Offline AdamMk2
  • Beautiful
« Reply #4 on: 22 May 2008, 00:16 »
Is the part under the scuttle panel completely flat???
Not sure if you have seen it, but its on here somewhere, by txting a number costing £3 they txt you back with all the details about your car, cheap HPI check, worth doing.
Im sure there must be a stamp somewhere else hidden, Im none the wiser where though sorry  :undecided:
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #5 on: 22 May 2008, 02:20 »
VIN plate is located on inner wing, up by the o/s bonnet hinge, and never on the slam panel!  C/N is stamped into the bulkhead panel in front of the wiper motor, and can be viewed through the black plastic cover that covers the wiper motor. build code sticker can be found on the boot floor or rear panel, and if your lucky, you can find the build code sheet, tucked under the carpet, under the rear seat... dont all rush now!
Tom
