Author Topic: head swap  (Read 811 times)
Offline dbs
head swap
« on: 21 May 2008, 17:59 »
hi is it possible to put a 1.8 or 2.0 head on a 1.6 block, i got a 1.6 GL and i thought about posting the head but then i had an idea or changing the head to a 1.8 or even a 2.0 i know i would need to change pistons and other items but is it possible
-J
Offline eightyeightmph
Re: head swap
« Reply #1 on: 21 May 2008, 20:52 »
I don't think so, totally different engines, the 16V is DOHC so that's a no no. Not sure about the 8V although it's injection & I'm not sure if the 1.6 is injections/ carb...
2016 GOLF GTD
Offline dbs
Re: head swap
« Reply #2 on: 21 May 2008, 22:03 »
ah no probs was just an idea
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: head swap
« Reply #3 on: 23 May 2008, 01:48 »
the 1.8L and 2.0L are a diffrent block.  you can fit a 1.4 or 1.6L head,  Now. if you have the pre 95 engine you can fit the post 95 AEE head with a few mods, this has better porting and you can also convert the fuel system to run the Multi poit injection but your much better getting the whole engine.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
