Author Topic: subframes...  (Read 1045 times)
Offline DogDay
subframes...
« on: 21 May 2008, 01:03 »
So... I wish to build a mk2 TD mutant...
I have an AAZ engine & gearbox from a mk3.... and I have been offered a straight mk2 1.3 at silly money...
presumably the 1.3 will have a different subframe to  to what I need? are sub frames interchangable ? all the ancilleries & electrics & plumbing & other gubbins I can handle - its just mounting the motor & gearbox that concerns me...
presumable I can just swipe the sun frame from a gti (with ARB ) and bolt it all up after a good clean & rebuild? I 'd be wanting to use 5 bolt hubs & rear beam anyway... so I know many many parts to be replaced.
DD
Bow Chikka Wow Wow
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: subframes...
« Reply #1 on: 21 May 2008, 13:19 »
I think all the sub frames are the same.  All golfs have the same mounts (well the MK2/3 are deffo the same)
One at the back to the left for the engine,  the main front mount for the engine and gearbox and then the rear right for the far right of the gearbox.
Should all be the same?!?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline DogDay
Re: subframes...
« Reply #2 on: 21 May 2008, 16:57 »
Ok... so I could then in theory just use the existing subframe and it would be easy to add the ARB to it?
I'm basically planning in using mk3 16v running gear - is this also a straight up fit?
cheers
DD
Bow Chikka Wow Wow
