Author Topic: Lowering your MK3  (Read 1110 times)
Offline MVP
Lowering your MK3
« on: 20 May 2008, 23:32 »
Quick question to all the guys with mk3 gti's,
looking to get them hot tuning coilovers when i get my car, how much do u recommend i get the car lowered by with these? probably get 16 inch alloys, maybe 17s
any ideas for both specs
cheers :cool:
Offline remapped
  • If you are going through Hell, keep going
Re: Lowering your MK3
« Reply #1 on: 20 May 2008, 23:44 »
between 65 - 75 front , and 50mm rear  :cool: :cool:
or if you are brave wind them right down
OEM(ish) G3GTi 8v5dr
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 21 May 2008, 09:13 »
Mine are going 50mm front and 30mm rear for everyday use (as its currently -40mm and scarpes on some roads/speed humps allready!!).....and then around 80mm/60mm for shows etc!!
Offline MVP
« Reply #3 on: 21 May 2008, 09:23 »
cool thanks for  the info
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #4 on: 21 May 2008, 11:46 »
Do you have to jack the car up and get in behind the wheel to adjust ?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
  • Back in a Mk3...
« Reply #5 on: 21 May 2008, 12:42 »
yes its a wheel off job....only takes about an hour or two for all 4
Offline DEANATRON
« Reply #6 on: 21 May 2008, 14:13 »
Also want to lower mine i the next two months.
What are insurance groups like on this also
HELP!
I use my car daily so dont want to proper slam it as much as i love the look.
I sometime have 2 people in the back of my car whats the most i could lower the back without it scraping?
i was thinking
50mm front
and 40 back
would that scrape?
Offline ineson
« Reply #7 on: 21 May 2008, 15:19 »
I have gone with a full Bilstein kit lowering it -35mm. I know its not much but like yours its my daily drive and dont want too much of a drop. Will let you know how it is when its fitted next week.
