Author Topic: Oh for heaven's sake (censored for sensitive ears lol)  (Read 1905 times)
Offline dub-diva
 AAAAAAAAAAARRRRRRRRGGGGGGGGGGGHHHHHHHHH  I HATE CARS  :evil:
Took MrDiva to work this morning (chucked £5 of petrol in on the way) and came home to take the diva-ettes to school. Oldest diva-ette had missed the bus cos she was doing her hair so had to drive her across town to her school... all was well until I was waiting in traffic and my fuel pump started to make a random but worrying squealing/whistling/bubbling noise and then my golf just... stopped  :shocked:. It didn't buck or kick or jump or do anything, it was as if my engine had been turned off... It started again straight away, pump started whistling/bubbling noise again then it died. Started it again and it seemed ok and moved closer to the busy roundabout that I was queuing at and then died just as I turned left managed to get it into a bus stop that was about 20 yards along. Tried to start it and the pump was sort of hissing then the car wouldn't start without immediate death  :huh:
Thought I'd better rule out the possibility of not having put in enough petrol this morning before I called the breakdown people out, so trudged a mile with the children in tow to the petrol station (that I had just driven past ) and got back to the car, emptied the can into the tank and waited for a couple of minutes. Started ok, pump was bubbling and had a muffled squealing noise, revved it a bit and it seemed ok. Drove diva-ettes to school and all seemed fine....
Until I was 2 miles away from home and on a one-track country lane when it started the random noise and died  :undecided: again  :evil: Was thinking several rude words whilst trying to start it and it seemed ok after the third try but the pump started hissing ... then I got it rolling again, but it would only reach 15-20 mph tops... then came a massive jump (no bangs or pops like backfiring, just the jump) and I got power back. Pump stopped making that god-awful noise and all seems alright now. :undecided:
Goodness only knows what's wrong with the stupid thing....anyone got any ideas?  :nerd:
Btw, it's a 1988 Mk1 Golf GTi cabriolet...
Offline Horney
Re: Oh for heaven's sake (censored for sensitive ears lol)
« Reply #1 on: 20 May 2008, 12:01 »
Could have been a blockage in the pump causing it to work harder and starving the engine.
Nick
Offline [han]
  • Graphic Designer for Haribo
« Reply #2 on: 20 May 2008, 12:33 »
sounds like the problems i've had, mine was a metering head issue.
thread are here
http://www.golfgtiforum.co.uk/index.php?topic=58905.0
definitely worth 5 mins fo your time to read:)
a mk2 early metering head will fit a gti cab too, and you can pick them up cheap, i paid a pint for mine form a mater, you just need to swap the airbox tops as the mk2 one is different.
we replaced the pump as cos the garage had spent almost a fortnihgt trying to start the pump, under stupid pressure it wasnt priming/working.
there is a filter in the lift tank i think that can get easily blocked, if its been run low on fuel youll pick upyears of debris from the bottom of the tank. i rarely let mine go below quarter to save this happening
good luck
Offline dub-diva
« Reply #3 on: 20 May 2008, 19:48 »
 :smiley: thanks for your help
Offline Agreeable Slick
  • Unit
« Reply #4 on: 20 May 2008, 20:52 »
First port of call change the lift pump, they are dead cheap and a easy swap. They normally go first and can then knacker the main pump.
