Author Topic: Front Engine Mount?  (Read 1046 times)
Offline capoot
  • Mk1 Skoda Octavia VRS
Front Engine Mount?
« on: 20 May 2008, 11:43 »
Any one got any idea how easily this can be changed? From my understanding its 3 bolts?
Anyone done this / have a how too?
Dan
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Front Engine Mount?
« Reply #1 on: 20 May 2008, 12:11 »
you un bolt the starter motor  (being sure to support the engine with a brace or a jack and block of wood on the sump)
Then you can bang the centre nut out the mount, might have two at the side as well i cant remeber but it is straight foward you will see what needs to be done when you look at it.   :smiley:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline capoot
« Reply #2 on: 20 May 2008, 13:08 »
Cool, i think im going have a go at doing it myself...
Cant be too hard can it?!
Offline capoot
« Reply #3 on: 21 May 2008, 16:17 »
i might be a bit confused... whats the metal bit that attaches to the gearbox then?
Offline Pete Taylor
« Reply #4 on: 21 May 2008, 17:28 »
I found the easiest way was to put the jack under the sump with a block of wood, undo the front mount from the top then undo the subframe (x4 16mm bolts if i recall) and pull it out underneath. You can then change the mount on the subframe and pop it back in. I took one look at the starter motor and decided I wasn't even going to begine on that!
Offline capoot
« Reply #5 on: 21 May 2008, 17:55 »
Cheers pete, but its not the rubber, its the acutal metal mount that im after replacing, whats this called, anyone got EKTA?
