Author Topic: Gear Linkage repair kit Mk2 gti  (Read 3653 times)
Offline jack0
Offline russ-vdub
  • Once a Dub, Always a Dub
Re: Gear Linkage repair kit Mk2 gti
« Reply #1 on: 20 May 2008, 12:38 »
Just get a mk2 one. Whats the point in risking it? A set is like a 10a from GSF, no waiting for delivery, no paypal charges.
Offline bigman_10
« Reply #2 on: 20 May 2008, 15:18 »
I could do with one of these and heres the gsf job.
https://secure.gsfcarparts.com/shop/results.asp
i can only seem to find the linkage repair kit for the 1.6/1.8 though not for a 1.3? would the 1.6/1.8 be the same do you think? i know its a five speed linkage though and i've got a 4 speed? how much difference would this make  :undecided:?
Offline AdamMk2
  • Beautiful
« Reply #3 on: 20 May 2008, 15:21 »
I had my likages done, thing is it was a bit more than that, I had the Bushes (where the rod goes through) and the metal part with the ball shaped bit on and it was like £60-£80 quid I think!!!!!!
Go to GSF and they can print you out a decent numbered diagram so you can check what is worn and get a good price mate
Offline Steve_B
« Reply #4 on: 20 May 2008, 15:39 »
There's a seperate rod for 5th gear so I think it's the same minus the bits for that rod. Worth getting the plastic linkage rod whilst you're at it, only a pound or something. As for the relay ball, there's someone on here who sells them, much cheaper than getting the arm attached to it as well!
