Author Topic: Help for a damsel in distress?!  (Read 1128 times)
Offline Gabber-Baby
« on: 20 May 2008, 09:19 »
Right, thanks for looking guys - basically, my 1.4 mk3 has just been fitted with a brand new clutch and cable, it finally burnt out on me at some traffic lights a couple of weeks ago, one of the plates was wafer thin apparently, and would have been sparking whilst driving  :laugh:
Anyway, got it back yesterday and took it for a drive to see how it was. The biting point is ALOT lower and the clutch itself sits lower i.e - it's not the same level as the brake and accelerator but ive been told it just needs a spring to bring it back up again, which is fine and I can live with it being low for now. It was driving fine and going into gear fine, but when it came to parking in Tesco car park, I was struggling to get it into 1st gear - I was forcing it with pretty much all my strength to get it into gear! It's also stiff getting it out of first gear, and when I put it into reverse it makes that awful clunking, grinding noise and the whole car shifts when it eventually gets into reverse.
I've never had this problem before and it's only been doing it since I got the new clutch fitted. Any ideas on what's causing these dodgy gear changes? I hope to god it's not the gear box which is going because iv just spent £340 on the damn thing  :sad:
My dad just says im not finding the gears properly, but like I say, Ive NEVER had this problem - sometimes it would be a bit reluctant going into first gear if I was driving ultra slow but alot of cars are like that but its more reverse that I'm concerned about.
Help meeee  :cry: x
Offline Horney
Re: Help for a damsel in distress?!
« Reply #1 on: 20 May 2008, 09:25 »
Sound slike the clutch needs properly adjusting. Not sure how you do it on these but I suspect it's cable operated. Also the shift linkage might need adjustment as they would have had to remove it to change the clutch. Take it back to the garage and tell them to sort it as for that money it should be perfect!
Nick
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #2 on: 20 May 2008, 12:32 »
Yeh sounds like they haven't road tested it properly and left the clutch adjustment in the wrong place. Like Nicks said, take it back and tell them you want it exactly how you had it before. They are obliged to.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #3 on: 21 May 2008, 13:30 »
they are auto adjusters on these.  Unless its a badly made after market cable or they have fitted somthing slightly wrong it wont make any diffrence to how the peddle sits.  The bite will be lower tho!!
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
