Author Topic: rear abs sensor  (Read 972 times)
Offline gtiscott
rear abs sensor
« on: 19 May 2008, 18:46 »
i know how to change it but my prob is i can't get an allen key(5mm?) in to undo the bolt as there is a bracket that holds the brake pipe in the way.....what do you guys use?
scott
Offline hd_andy
Re: rear abs sensor
« Reply #1 on: 21 May 2008, 12:00 »
You need a 5mm hex socket.
http://www.mytoolstore.com/sk/19706.jpg
I changed one yesterday - taking the bolt out was the easy bit, getting the sensor out in one piece was impossible! They are quite firmly wedged in, I broke it in the end taking it out.
Offline Pete Taylor
Re: rear abs sensor
« Reply #2 on: 21 May 2008, 17:33 »
Taking the sensor out is pretty simple too...
Make sure the handbrake is off and the car is in 4th gear when you jack it up roll it until the gear engages to stop it moving when jacked up. A lot of people will tell you to break the sensor out, far too much effort... If you get a square headed socket screwdriver or something similar.. poke it through the wheel bolt hole in the hub... spin the hub so the screwdriver is at the top, then you can feel using the screwdriver where the sensor pokes through from behind, put the screwdriver on the sensor and hammer it out from the front and it will come out in one piece. Before you put the new sensor in, clean up the hole with a small brush and WD40
The cable you'll notice cunningly clips into a tray that also holds the brake pipes, run it along these then back through the floor under the rear seat and plug back in
Offline gtiscott
Re: rear abs sensor
« Reply #3 on: 21 May 2008, 19:10 »
thanks guys, bought a hex socket  set off ebay, so will get it done at the weekend, cheers for the info pete, i have already saved your how to guide to favourites :laugh:
