Author Topic: TDI turbo issue  (Read 2987 times)
Offline petefair
TDI turbo issue
« on: 19 May 2008, 18:14 »
My tdi115pd turbo spins up the strongly from about 1500rpm but dies off around 2100rpm, the other issue is it seems to come and go, hesitates at 2000rpm after which you cannot hear the whistle though pulling power does not seem 100%. I had a maf go which was replaced ( non original ) and before that it worked fine. Could it be the n75 going or is it a duf maf, I cant find an air leak. Forgot to add it smokes a bit more when booting it and when cold at low revs seems like its over fueling itself.
Any suggestions / help would be appreciated.
« Last Edit: 19 May 2008, 18:17 by petefair »
Offline Ridg
  • TDI - Soot Happens!
Re: TDI turbo issue
« Reply #1 on: 20 May 2008, 08:59 »
i'd sy double check the hoses for a boost leak, as something could be popping out under pressure from the turbo.
if there is definitely no leak, then try and get it connected to vag com to try and spot and MAF issues, the clone MAF's can be a false economy.
Offline christianduncan
Re: TDI turbo issue
« Reply #2 on: 15 June 2009, 14:40 »
hi mate,
im having the same probs, when i boot my car it puts out what i would say is more than average smoke.  this is more notice able at night when a cars lights are behind me.  i occasionaly loose my turbo and it boots up again. ive also have a new maf sensor which is a bosh one not the exspensive vw one.  help meee please...
haha :-)
