Author Topic: Mk4 Brake lights help!  (Read 1281 times)
Offline PM1967
« on: 19 May 2008, 10:39 »
Both the brake lights on my Mk4 have gone, I checked the fuses and bulbs and they both seem fine. Can anyone help? Anyone had similar problems?
Also anyone know if you can get the manufacturers wiring diagrams etc online?
Cheers in Advance
Offline J5H VW
Re: Mk4 Brake lights help!
« Reply #1 on: 19 May 2008, 12:33 »
Does the LED light at the top of the rear windscreen still work?
If not, and like you said you have checked the fuse/bulbs.....my guess would be the brake light swtich.
If it does still work, then the switch must be ok - and the fault must be elsewhere.
2001 VW 1.8t Golf GTi 5 Door (AUM). Xenons, Heated Black Recaro Leather, Front Arm Rest, Stubby Alloy Bee-sting, Climatronic, Heated Washers, Headlamp Jets, Touareg Torch...and a fire extinguisher should it all go wrong! - NOW SOLD
2005 BMW 330cd M Sport Convertible - Sparlking Graphite, Full Electric and Heated Red Leathers, TV, Nav, Bluetooth, Active Xenons, Wind Diffuser
Offline PM1967
« Reply #2 on: 19 May 2008, 12:49 »
I'll have a look at the LED light.
Offline Rhyso
« Reply #3 on: 19 May 2008, 12:52 »
most likely the brake switch behind the pedal
£8 from the stealers and 10 minutes or less to fit :afro:
Offline richw911
« Reply #4 on: 20 May 2008, 18:16 »
Yep as rhys says Very common fault This may help:
http://forums.vwvortex.com/zerothread?id=1158315
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #5 on: 20 May 2008, 19:13 »
yep, the switch, common as hell, and if i remeebr correctly theres 2 types, an early one thats easy and a late one that a right bugger to fit!
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline GUY_GTI
« Reply #6 on: 21 May 2008, 16:16 »
yeah definately 2 types, one breaks if installed incorrectly which is a bit of an ass
watch the sump ask guy he went over a some toilet paper and it carcked!!!! :laugh: :laugh:
