Author Topic: Spring plate........  (Read 1061 times)
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« on: 18 May 2008, 22:59 »
Well since having my jamex suspension fitted a cuople of months ago ive had nothing but trouble...sorted out most of it but now having a problem with the plate that sits directly on top of the spring on the d/s/f.
It keeps wedging itself inside the 1st coil and causing a knocking noise, sure its not doing the spring any good either. How can i sort this..? Is it possible to get a bigger spring plate or is it just that the plate thats put on there is incorrectly placed..? its on a 96 vr if that helps.
Offline Stu G
Re: Spring plate........
« Reply #1 on: 19 May 2008, 10:56 »
from the sound of it i think the front springs are too big for the top plate.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #2 on: 19 May 2008, 11:13 »
You have been sold older model springs but you have a post 95 vehical with the smaller spring caps.  the pig tails on the spring are slightly bigger on the MK2/MK3 pre 95.
I have the same problem and i reset it a few times, its been fine for about 6 months now which is a supprise but there are three options
Caps from the dealer are £15.00 each (need to get the for a MK2) or they insist on giving you the smaller ones
Scap yard,  couple quid each.
Or you can fit lowering caps which are again... arround £15.00 each and lower the car another 10/15mm
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 19 May 2008, 12:45 »
As said youve got wrong springs...thats 65mm after 95 pigtails and 80mm before.... there's loads of lowering caps on ebay for cheap prices.
my old gti was a 01/95 and had early ones but my current 02/95 has later one's... they changed in 10/94 according to vw!!
Offline Rmachines
« Reply #4 on: 19 May 2008, 12:50 »
In my case if i droped it another 10/15mm with the caps the car would be wedged on the tar mac as im only on 15s  So i had to leave it for now but its been ok.   but you wont pay much more for new ones from the deeler.
Offline DazVR6
« Reply #5 on: 19 May 2008, 18:16 »
Well jacked up the car and used a screw driver to unwedge it again. So getting bigger spring caps will solve this but otherwise no adverse affects..?
