Author Topic: temp gauge  (Read 5516 times)
Offline eyeletboy
temp gauge
« on: 26 April 2004, 23:14 »
hi all,my gauge seems to be eratic on cold start.when the engine is hot the gauge settles down to the normal position.i have cleaned the connections but it has not helped,could anyone give meany ideas?
Veedubgt18v
Re:temp gauge
« Reply #1 on: 26 April 2004, 23:17 »
faulty sender? they arent that expensive from vag, about 8 quid if i remeber correctly
Offline eyeletboy
Re:temp gauge
« Reply #2 on: 26 April 2004, 23:20 »
just checked out price of sender from gsf.?3.95.gonna pop down and try that first.cheers vdub.fingers crossed. ;)
Veedubgt18v
Re:temp gauge
« Reply #3 on: 26 April 2004, 23:31 »
s'alrite  ;)
Offline eyeletboy
Re:temp gauge
« Reply #4 on: 01 May 2004, 13:33 »
how do i fit the temp sender?do i need to take the housing apart?if so do i need new seals?is this job difficult?
Offline richandhazel
Re:temp gauge
« Reply #5 on: 01 May 2004, 13:37 »
Temp gauge sender unit should simply unscrew from the housing.......screw new one in.
Can't remember if its an o ring or washer, suspect o ring. Either way, ideally, you should replace.......however if its not damaged you'll probably get away with re-using.
Offline eyeletboy
Re:temp gauge
« Reply #6 on: 01 May 2004, 13:42 »
i'll go and try it now,but the new gauge looks to big.brb.
Offline eyeletboy
Re:temp gauge
« Reply #7 on: 01 May 2004, 13:49 »
the gauge is to big!!ihad it from vw so the part number must be right?the connector is the same but the body of the part is to big.
Re:temp gauge
« Reply #8 on: 01 May 2004, 13:50 »
Sure you got the right one? Temp gauge one is in the housing at the opposite end to the timing belt, if memory serves me correct.
Offline eyeletboy
Re:temp gauge
« Reply #9 on: 01 May 2004, 13:51 »
hold on i'll be back.
