Author Topic: stuck in 3rd gear  (Read 3177 times)
Offline MAT ed30
stuck in 3rd gear
« on: 18 May 2008, 11:11 »
been out for a blast in the mk2 and just get stuck in 3rd and will not come out  :cry: i think the box must be fooked as it will not come out of 3rd no matter how hard i try  :sad:. The car is a 1991 mk2 golf gti 16v
any help would be good and how easy is it to change the box on the golf?
EDITION 30 NUMBER:- 1038 ,Forge dv,ecs dog bone insert,Tints,inpro smoked indicators,panel filter,Black badge,Black roof,Black wing mirrors,REVO stage 2,Blueflame TBE,neuspeed arb,Neuspeed drop links,KW V3,S3 Intercooler,VWR clutch and LSD,VWR 6 pot brakes,1956 vw beetle (2332cc)
Offline Mew
Re: stuck in 3rd gear
« Reply #1 on: 18 May 2008, 11:15 »
My mate's driver got stuck in first. We couldn't get it out of gear at all, he scrapped the car after that!
That said, are you sure it is stuck in gear? Have you tried moving the linkages in the engine bay yourself as it could just be a dodgy linkage not allowing enough movement on the stick.
Offline MAT ed30
« Reply #2 on: 18 May 2008, 14:49 »
yep took all the linkages off and still nothing just will not budge  :sad:
Offline AdamMk2
  • Beautiful
« Reply #3 on: 19 May 2008, 00:48 »
Assuming its a cable clutch check the cable that heads in throught the top, I know you should be able to pull a car out of gear however you never know what might work, as you probably know its not uncommon for the gearboxes to Fook up, just absolute wank  :undecided:
Hope you get it fixed mate
Offline MAT ed30
« Reply #4 on: 19 May 2008, 11:42 »
its fooked  :sad: so anyone got one for sale around west yorkshire for a 1991 16v 020 box please  :smiley:
Offline Ben Lessani
« Reply #5 on: 20 May 2008, 16:17 »
Mine got stuck in third, took about 30mins of hitting the lever arm on the box and swearing a lot and it free'd back up...
...I think it was the swearing that helped.
Offline MAT ed30
« Reply #6 on: 20 May 2008, 17:00 »
well i dropped the oil and its got bits of metal in the oil so i am going to pull it out tonight and have it looked at by a gearbox man i know and will see what he says  :smiley:
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #7 on: 20 May 2008, 17:17 »
ahh the bits of metal sound like the sycro-mesh has blown up. These 020s can be repaired, just not an econical repair if you get me. Cheaper to buy a new one unfortuntely
Offline MAT ed30
« Reply #8 on: 23 May 2008, 20:48 »
well i have had the box rebuilt today and it only cost £145 parts and labour  :smiley: from a gearbox firm i have used for years in Leeds.
this is what broke
the little ball bearing goes inside that big bolt and is captive well not mine it fell out and got stuck lol
i had them replace any thing that looked worn aswell just incase
Offline Ben Lessani
« Reply #9 on: 23 May 2008, 23:08 »
Wow, £145! I got my 2nd hand box for £40...works just fine :)
