Golf mk3
hardmonkeys
Fuel pump removal and replacement
Topic: Fuel pump removal and replacement (Read 634 times)
leegt5
17 May 2008, 22:22 »
Is this a big job ?? I know its located under the boot floor but is it a hard job os simple enough ??
LEE
Support London's Air Ambulance
eightyeightmph
Re: Fuel pump removal and replacement
18 May 2008, 10:34 »
From what I've read it's pretty straight forward, got mine to do at some point....
You'll need fuel line clamps/crimps to stop fuel going everywhere.
A new set of 'O' rings & the pliers to put them on & that's about it!
2016 GOLF GTD
bored_Welsh_lad
18 May 2008, 11:05 »
Fuel crimps...
bend the pipe and cable tie it
cheap alternative!!!!
Dicky
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come
Bumper Vents
Golf mk3
hardmonkeys
